When looking at the front of the block, check out the left galley hole. Just below the surface you'll see where the oil goes to that galley from the pump. If you put a plug in too deep, you'll block off the oil flow and starve the engine.
From the factory those plugs were press fit like a plain ole freeze plug and someone along the lines tapped it for a tapered pipe plug. MAKE SURE they didn't run the tap down so far that it causes a restriction. To make things worse, it's located after the oil pressure tap, so if it is a restriction it'll make your oil gauge read higher while at the same time smoking bearings.
I probably wouldn't blast that cover. It wouldn't take much abrasive media to ruin your day after the engines built.
