MeanBuicks
Scaring the neighbors!
- May 24, 2001
Geeze! I've been around these goofy cars long enough to be able to pinpoint about anything but the old GN has got me flamboozled!
Under a load it runs real clean until 4000 rpm and just hits a wall. The engine just breaks up and stutters real quickly just like the stutter box on a bracket racing car. Won't do it at all below 4000 rpm or if there is no load. In park/neutral, it'll wing right up to 5000 rpm quicky & cleanly. Here's the skinny:
- New Comp roller cam, beehive springs, pushrods, double roller timing chain. (About 3000-4000 good running miles on this stuff.)
- I've checked the turbo, pulled the intercooler & cleaned it.
- Tap tested the MAF and monitored it with the Scanmaster. Seems OK.
- Checked all the grounds under the hood.
- I've swapped the coil & ignition module.
- swapped ECM & chip
- swapped ESC module & tried unplugging the knock sensor
- checked plugs & wires
- readjusted cam sensor
None of this has changed anything one iota.
Is it possible that a valve spring/springs have gone sour? Would the engine run like a top with no load if there was a valvetrain problem?
Help?
Help?
