I've been trying to purchase a 105mm throttle body with a wiggins clamp provision for over a month now. I've decided that I'll just make my own. The throttle arm will be on the right side (actually, left side) too. Everything is designed for the Mustang crowd these days. Arggg!
I can make several, if anyone thinks they can use one. Otherwise I'll just make one prototype for myself. The more I make, the cheaper the product. Let me know.
It will feature:
Billet 6061 T6 aluminum body.
105mm throttle blade.
Bushed or if possible bearings for throttle shaft.
Throttle shaft seals.
Built-in Wiggins clamp provision (4 inch) or if wanted, normal hose provision.
Variable pull throttle arm.
GM IAC mounting. Not Ford.
GM TPS mounting. Not Ford.
Throttle arm on left side of body. Not right.
At this point, no vacuum fittings.
No coolant preheat passage.
Four mounting holes.
This will be a custom balls to the wall installation piece, so don't expect it to bolt onto a stock application.
It will feature:
