Huge Parts List MORE CRAP PARTS FROM THE NUT
Status
Not open for further replies.
Buick Mom
All parts are from 86/87 Buick GN or T types.
All prices plus shipping
High pressure PS hose $25
Ps hose from reservoir to pump $20
Crank Pulley x2 $10
Balancer 86/87 $85
Battery Hold Down $30
ac/alt/ps bracket $45
3 piece vacuum hose from vacuum block $15
rocker arm shaft assembly's complete $5 each x8
stock down pipe elbow $20
chassis service manual/body service manual/gm parts illustration manuals $285
hvac cable (short one) x2 $20
trans mount $10
Cam Sensor $90 x2
Cam Sensor Cap $40 x4
steel fuel lines at tank 3piece $25
Dip stick and tube $90 x2
Door strike seat belt retractors $25 x2
rear package tray end caps $5 each x4
Rear Package tray $45 x2
Boost guage with pod $65
Water pump pulley $5 x4
Rear speakers $10
OEM upper hose part number 2552229 $20
Left and right side A pillar molding $40
B Pillar molding $20 a set x4
shift cable $15
shifter cable bracket at transmission $25
Oil cooler hoses $25 x2
Oil cooler adapter $25
Turbo drain tube $40
passenger side header good no cracks $75 x3
drivers side header cracked $75 x3
Passenger side Header cracked $25
Crossover $50
Relay bracket on passenger fender $20
3rd brake light and bracket $50
Tail light Harness $30
Headlight Harness $30
Oil Fill neck $40
stock valve covers $65
Chrome plated stock Valve covers $80
Injector Harness $10
U bracket for coil $20 x3
HVAC control head manual $40 x2
TPS $10
Ash Tray 2 holes in bottom $10
Shifter linkage from column to trans $45
Headlight switch plastic bezel that bolts to dash $25x2
3" maf pipe for use with maf $40
Grey glove Box $25
AC L Bracket $20
Ac Dash Vents $5 each X4
Steering Wheel needs re covered $45
Rear quarter panel extensions $40
Starter Heat Shield $5 X2
Alt/AC Y bracket (front) $15
HDBoost Actuator $40
Fuel lines from Frame to Rail $50
Front Arm rests set $20 X2
Rear Sail Panels $25 a set x3 sets
Catch Can $20
Grill springs $30
Air Temp sensor pigtail new from Caspers $5
Sliding cover on shifter (ribbed piece)$10
License Plate holder flip down $10
Throttle Cable $25 X2
Radiator Top Plate $45
Front Bumperetts $10 pr
Up Pipe steel $25
Dash cluster holder (black piece behind the cluster) $30
Left front kick panel $10
Single gauge pod $15
Clear Plastic piece that covers instrument cluster $15 x2
Drivers side Visor $10
Dash Frame around the cluster $35x2
Throttle Cable $25
I would like the above parts.
Can you post a picture of the radiator top plate. I dont want one that is badly rust pitted.
Throttle Cable $25
Here is top plate.
Sent from my SM-N950U using Tapatalk
I would like the injector harness for $10.
Please let me know shipping to 43315.
Shawn
Do you have pics of following?? Put me in line for these
AC L Bracket $20
Y bracket,1 throttle cable and radiator cover,throttle bracket,and 1 cam sensor sold.
SOLD AC/ps/alt bracket ac L bracket ac y bracket 1 throttle cable rad top plate.
Status
