map I.D
SLICK6
I've done some checking and this is what I found.Map sensor part # is 16009886 or #213-183.Voltage @ center pin ign on car off is 2.36v what the f---- do I have here?.This is the map sensor that was supplied with the cyberdyne dash # 5202.It is supposed to be a 3 bar .I am beginning to think it isn't.Any thoughts on this?
Are you for sure on having the + and - correct?.
If they're correct and you have ~ 2.5v that would be a 2 bar.
Three bar sensor reads 1.6. Two bar sensor reads 2.4 approx. That is with 5 volts applied to power, and ground on the ground. No vacuum or pressure present on its port.
If its a 2 bar, it will only read to 15 PSI. Actually 14.7 PSI.
