larrym
West Coast Newfy
- Jul 17, 2007
I have a 71 Vega with GN running gear stock computer and wiring harness, the vega wiring runs lights and the starter I have an auxilary fuse panel for the engine managment, alky kit, wideband and fuel system. The C100 bulkhead connector has been eliminated along with that wiring.
So I wired my power logger to the green wire terminal A on C437 like I had it in the Ttype and nothing, the connector is not connected to anything and I have ran power to terminal F to run the motor, there is no power at the map sensor and I have probed the C437 connector terminal G black and white marked as ground has 5 volts? Nothing at terminal B I jumped the G and B together and got a reading of 20 PSI on the powerlogger? Is it as simple as grounding terminal G?
