SignUp Now!For an installed height of 1.900", a Manley Professional valve spring looks good for your application. I've heard some amazing things about these springs at the track. My next set will be Manley.
For yours:
Part No. 22438-16. Advertised pressures achieved after springs have been compressed solid three times.
Type: double w/damper
Application: drag race, H-11 tool steel
Size OD/ID: 1.625", .775"
Pressures: 328 @ 1.900", 806 @ 1.200"
Coil bind: 1.090"
Rate (lbs./in.): 682
Super 7 Ti retainer: 23669
10 Ti retainer: 23654 (std.), 23655 (+.100")
I personally prefer the Super 7 arrangement, but I know the 10 has its place with the really high spring pressures.
i love your input Don,
installed height is 2.000 +/- 0.005
i have the super 7 locks
any reason for a spring with the damper?
No reason. That particular spring package calls for one.
If you prefer not to use a damper, then the Manley Nextek 221447 or 221447P looks good. They are a triple spring and would work with your 2.000" installed height.
i will call around for price and availability on all the springs, i guessing you have tried a few different spring combinations Don?
looking at trying a NGK bpr6efy-9 (its a v groove electrode)
any thoughts? i don't seen the need for race plugs
also any thoughts for exhaust system with N/A motor?
cheers simon
Just don`t focus only on the Springs to solve this problem. Their is more to it than that...:smile:
im thinking the springs are a big part of it since the spring rate is only 494lb/in. as we all know there are so many vitial parts to a N/A motor, just would like to have as many things as possible to try when i go on the dyno soon!
definately open to all other suggestions!
but valve springs here we come!
things to try; plugs, lighter oil, without pipes, timing, different carb, mixture, springs, octane booster?
cheers Simon
Another Carb for sure... Do the Holley Calculator ( C.I x RPM = CFM )
Holley or Barry Grant...etc..Double Pumper all the way...
Do you really think that the carb should change? I would think it would bog to much out of the hole with anything else as it sits, maybe if the valvetrain problem is sorted out.
A.j.
I would never used Vac Sec. carb. I have tested this years over years and never liked them. It will make a noticeable difference I am sure in solving some of this problem.
Just adding opinions... ANY carburetor will require some tuning on one of these engines. Given equal pressure drop and fuel curve, a V/S and a DP will make equal power. Throttle response and ET incrementals are a different story. Did you get any Air/Fuel #'s from the dyno? Maybe it went pig rich OR lean. Either way could easily kill 40 hp without blowing it up. Could be as simple as a jet change...I wouldn't dare discount a spring problem as there hasn't been any mention here of how old the springs are, nor of valve size or material. Greg
What did you change between the runs on 1/2 and the run on 1/4?...The air/fuel got much richer and the power didn't fall off a cliff. Overall power looks pretty low. Are the secordaries opening? GB
