SignUp Now!Yes, but...you have to get the diameter of the shaft and find the center. Then measure the distance from the center of the fulcrum (roller) to the center of the shaft, as well as the center of the pushrod location to the center of the shaft. Then some simple division and you've got it.![]()
Did you get them from bison? If so they are 1.65s
You can take the rocker off and measure off the pushrod. The lift at the valve can be slightly altered by the geometry too.I agree with Bison. The most accurate way would be to measure lobe lift (written on cam card) then measure valve lift (with a dial indicator and a solid lfter on the cam--because a hydraulic lifter will compress under the weight of the valve spring) You can get close by just measuring the fulcrum diameter, "guessing" the distance from center of push rod to center of fulcrum. (guess because it'll be tough to get an EXACT measurement) and then "guess" the measurement from center of roller tip to center of fulcrum and then "do the math". The closer the pushrod is to the fulcrum centline, the higher the ratio is.
Geometry?? Oh MAN......I hated that in college.You can take the rocker off and measure off the pushrod. The lift at the valve can be slightly altered by the geometry too.
