Jul 21, 2004 #1 J Joesmoke New Member Joined Jan 26, 2004 Messages 17 Any suggestions on what size methanol lines I should run? (from resovoir to pump to solenoids to jets) Heres the intended setup: 100 psi shurflo solenoids hobbs switches 2 jets (m2 and m3 to start with, but will probably move up) Thanks
Jul 21, 2004 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 Tank to pump, -6 which is 11/32 or use 3/8 hose that is alcohol compatible. Pump to nozzle/solenoids -4 or 7/32-1/4 inch high pressure hose.
