We've been using ethanol for awhile now... again I havent *directly* compared them, but it works for us. One of these days ill do a direct comparison, athough i'd image the pickup would probably be only slightly noticeable and actually hard to compare since you need to reset the injection parameters... so much for holding a control variable at optimal levels ?!
I think it would be more important as to what is more easily obtained by you, based on your location and suppliers in the area...
Ahhh, the latent heat #'s ... I think they're a lil off, its been awhile since chem but...
L(H2O) = 2.262 MJ/kg (Pretty darn sure of that - your number seems quite a bit off - you even said it - water takes longer to evap than alky
L(Meth) ~= 1.5 to 1.7MJ/kg so your pretty good on that
L(Eth) ~= 0.93MJ/kg - right on
all at 1atm, of course...
Your math just went off from a lil error, here's it in factor label:
(540cal/g)(4.19J/cal)(1MJ/1000000J)(1000g/kg) = 2.262MJ/kg ... just a tip that helped me on doing that conversion stuff: make sure your units cancel to provide the right output units. You could even do it "upside-down" and it would still work; ie. you started with 1g/540cal... your output would just be inversed too.
You cannot simply look at these numbers however, as the latent heat will only describe the energy in heat absorbed by that chemical... combustion heat, pressurization, and boiling points (eth has about 20deg F higher than Meth)...and many other vars. play a large role too. Also, latent heat formulation is based directly on boiling points - ie. to convert 1 mass of water at its boiling point 100deg C to the same mass of "steam" vapour, you need that latent heat energy/mass... Gasoline's boiling point varies GREATLY, based on all the chemicals your gas station puts in it (emissions, that detergent crap, etc.)... so idk how they find that number... i guess its just an average?
As for the question of if higher L's are better, yes... but like I said, there's always more to a story than one set of constants... heck, its math... if all of our explainations could be based on one constant or formula, well then nature would be damn predictable and I'd be making my nanotube ladders to the moon. So thats why its more fun to me to just dump a gallon of each in the tank and goto town!
