Misc. rear Baer brake parts for the DIY builder
WHITE T
Baer Brake Systems
Guys,
I have some misc. Baer Brake rear pieces lying around from past builds that I am putting up for sale. These are not complete, but for someone looking for parts to make his own system, these are what is needed!
Rear 12" x .810" slotted, drilled and zinc plated rotors. These were installed on a car but never run. List for $300.00 pair, selling the pair for $175.00
Rear 12" x .810" 2pc (black aluminum hat bolted to rotor ring) slotted and zinc plated. Ran on car for less than 1k miles. List for $425.00 for the pair, selling for $250.00 pair.
I have one set of caliper brackets for the above rotors. These are designed to mount to the factory 10 bolt and allow you to bolt a 93-97 Camaro caliper to these rotors. List $85 each, selling $50 for the pair. I want to sell these will (1) set of the above rotors to make a system.
A set of used single piston aluminum PBR calipers (painted grey). These are the same pieces used on the 93-97 camaro. These will work with the above pieces.. and DO NOT include park brake mech. Selling the pair for $150.00
If some one want to buy all the pieces for the 1pc rotors (caliper, brackets and rotors). I will cut a special price of $350.00 Or if someone wants to buy all the pieces for the 2pc rotors (caliper brackets and rotors) I will sell for $425.00
Again... This will not be everything need to complete the install, but get you most of the way there.
Any questions, or want pics please PM or e-mail me.
Thx!
Some pretty good deals there...I haven't researched it, but can the brackets be used on a car with c-clip elim axles?
Bump for a good seller!
If I wasn't buying a house, I'd be all over this setup. I might do it anyway if you've still got it in a couple weeks.
STP, yes they will work with c-clip eliminators (I assume you mean the bolt on billet block?). This bracket will take place of the drum backing plate. It is slightly thicker so you would need to run a small spacer/shim (.125") between the caliper and mounting bracket to get the caliper to line up over the rotor.
INEEDAGN Thx!! appreciate it!! :)
Thx guys!
Eric,
I have fit this in some 15" wheels, but designed for 16".
I have sold this same set up for (2) different GNX cars also. So yes, shouldnt be a problem!
Let me know what you are thinking.. I can put it with your other stuff :)
Thx!
Rick, I'm interested in the complete 2 piece setup...What would be needed to get the ebrake to function with the PBR calipers? Thx Scott
