miscellaneous stuff. 3"dp w/ ext wastegate
3" black powder coated inlet pipe $25 (pending)
If this isn't sold, I will take it. Just let me know
How fast has the 206 roller cam been and I have a 70 with a .63 housing Is this a good match what stall conv do you recommend Bison
9.80's@138+. Im not sure what converter was used but id guess it was a PTC 9.5" and that would be the only converter id use. You would need a purpose built engine to get that kind of performance out of it. 10.50 would be typical with decent heads and 24-25psi with other supporting parts. You will be running 30-32psi with a T70 P on an 8:1 engine with a decent intercooler and 116 octane to get that kind of power.
Brian,
Hope you enjoyed the trip to Ca.
Here are the parts I am interested in,
1. Good set of stock valve covers, stock studs and bolts?
2. Heat Shield
3. Stock Fuel rail w/studs /bolts
4. stock injector harness
Shipping 92344 Paypal, Let me know?
Steve
