TurboTerry87gn
- Mar 3, 2003
Well I removed the plugs to take a look at them.
Ohm'd the plug wires 558 to 633 ohms except numer 1 fluctuates 1 to 20 k ohms has a bad connection at the coil side snap connector. I also ohmed the coil towers. 1,4: 11.92 k ohms; 2,5: 11.47 k ohms; 3,6 10.70 k ohms .
open from any tower to ground and open between adjacent coil packs.
Does this 10.7 k ohms fall within spec? on 3,6 tower.
Any reccomnedations for new wires. I runnig some spiral wound old ATR wires now. I was thinking the Taylor 10.xx mm spiral wound wires on summit racing site.
Before you ask the a/f is at 11.7 with 24.5 advance. Not sure if I had any voltage drops didn't log the right dashboard.
Runs fine at idle and at medium load only at high boost. I'm running autolight 103's Not sure if that bad plug wire would cause the bad misfire but I'm going to change it anyways. Seems like the high potential voltage wouldn't be bothered by the bad connection on number 1 wire but we'll see. It seems like it would jump right over it with only a minimal loss.
Anyone been down this road before. Missing only under high boost? Plug color looks good.
