Can someone share with me the chip mod to prevent a GN from stalling with a high stall convertor. I have already implemented the same mod as Lubrant does by increasing IAC at 32*C by 20 and 56*C by 40. In this case it did not work out to well. This car has a very loose convertor and goes down to 400-500 rpm at a stoplight before it completely stalls. It is a 9X11 from Bruce T and stalls to 4000 on the brake. I have direct scan file where you can visually see the rpm hit 500 rpm letting off the gas after an 1/8 mile run. Any help is appreciated..
M. Banas
87GN
M. Banas
87GN
