We have the glass seal getting tweaked as we speak. This is just a few pics I took of the new Pan seal today.
The fit is perfect with all the cut outs in the same original spots. Seal is slightly larger for a Full seal to the roof where the GM unit had a small gap by the roof support. This seems to seal a lot tighter. This is where you would see your head liner getting wet from. Ot is not designed to hold water in the pan but to keep water & other objects from getting past the pan into your roof area.
Check it out & give me some feed back.
The glass seal was dead on but we noticed when installing the glass grabbed the seal which wouldn't allow it to close 100%. I read a few posts on here where people had the same problem. We are getting the seal a little slicker of a compund to allow the glass to slide against the seal for the best optimal coverage & seating.
