Pull one of your plugs out after you attempt to start the motor and see if it is wet with fuel or smells of gas...If the plugs are getting spark and you have good compression, then as has already been said, it should pop or try to fire off...I think you may have a fueling problem...Also, when you turn the motor over, keep an eye on the fuel pressure guage, and see what it does...
You said the car ran before you did the motor??? Was the pump hotwired before or did you put the hotwire on at the same time as you put the new motor in??? If you just put the hotwire on, disconnect it and put the stock wiring back in place and see if it starts...I think I heard that some people were having some type of problems with hotwires, and I seem to remember that the cars wouldn't run...
Just brainstorming here...keep trying, we'll figure this out...
 I still wonder what the odds are of EVERY injector being frozen up.
