More GN Parts 4-Sale--Engine/Int'r/Acc/Susp'n
TurboMonte 2
Car Nut
More parts/final listing for "spare-parts" remaining from my 87 GN, which I've sold...All parts are for 86/7 GN; prices are plus-shipping; and parts are in good working cond'n---unless otherwise noted...Paypal preferred (I'll suck-up the fees) and no personal checks please...Shipping to Cont'l US only...My Paypal is: monte29568@hotmail.com ...
ENGINE
LT1 MAF Sensor, tested good, no screen--$30
160 degF Thermostat--NEW--$10 shipped
Plenum + Vac Block Gasket Set--NEW--$8 shipped
2-PCV's, AC Delco CV893C--NEW--$8 each shipped
Misc. Brackets--(per Pix)--$8
Adjustable Turnbuckle-style metal engine tie-down/"torque-strap"--$5
EGR Valve + Hold-down Bracket + Cover (cleaned...)--$20
EGR Valve + Hold-down Bracket (not-cleaned)--$9
Stock Intercooler (IC)--$45
Stock-size IC conn. Hoses--$8
Stock Fan & Shroud, no resistor--$40
Coil Pack, like NEW (used for testing), all good cold resistances--$30
ECM #1226469 (for 84/5 Hot-Air) with both chips (appear stock)--$30
Following Engine hard-parts w/ approx 25K miles:
6-Keith Black + 0.030 hyper pistons w/ rings & wrist-pins--$50
12-Push-rods, 5/16" dia X 8-11/16" length--$12
Water Pump--$10
Alcohol/Methanol Related Stuff:
5-gal Poly Tank, w/ 4+ gal Methanol, 1-gal portable meth'l tank, Meth Lube/Additive (enuf to treat another 40+ gal)--PICK-UP ONLY--$40 ALL
INTERIOR/ACCESSORIES:
2- Climate Controllers w/ levers & tips--$30 each
2- Steer'g Whl Center disks; "T" & "T-TYPE"--$10 each shipped
Steering Wheel (pre 86/7), needs refinished--$25
Power-Seat Ass'y (86 w/ single motor), complete, incl. switch, for parts--$30
Cruise Control Electronic Module, goes under dash, tested good--$40
Cruise Control Cable (diaphragm to Thr Bdy Lnkge)--$9
Cruise Control Wiring Harness (goes thru firewall)--$9
AC Condensor w/ mounts/brackets--$30
AC Drier/Receiver (black) w/ switch--$12
Window Washer Tank/Cap/Inlet Hose/Screen--$12
Pr-Front Seat Belt Receiver-Clasps w/ covers/shields--$18
Pr-Seat Belt Clips (on seatbacks, grey)--$12
2-ETRON Headlamp Dimmer switches--NEW--$15 each shipped
2-EVERCO A6429 Temp/Fan Switch--NEW--$13 each shipped
WHEELS/ SUSPENSION:
Pr-Boxed, Stock LCA's, nice, painted black--$50
6-Stock GN Wheel Centers, good tangs, (cleanup/paint suggested)--$6 each, $30 ALL
4-Alum. "CenterLine Champ 500-Style" Wheels, stock GN dimensions--$100 ALL
4-Stock GN Wheels (15x7), painted black, some rust inside where chrome flaking off--$100 ALL
THANKS FOR LOOKING --I'll post (hopefully) some parts-pix later today...
I'd like to see the Misc brackets. need a few.
This too:
Parts Pix
I'm now going digging for parts pix: My 1st Group will be for some parts listed under ENGINE
Pls note:
1) Cam shown w/ pistons already sold
2) EGR Soleniod (to be later shown w/ EGR Valve/Cover/Brkt Pix) to be listed/sold separately,
3) ADD EGR Soleniod--$15
4) ADD 2 Wiper Arms (I think they're both Dr's Side)--$10 each--Pix to be shown later,,,
Monte
Oops, couldn't find Cover to go w/ "clean" EGR Valve + Brackt--SO, make that Item $15 vs. $20 listed (incl. Cover)...
More Pix (ENGINE & INT'R/ACCES..)
I'll limit pix to 4-5pix/post--here are the next...
More Int'r/Access. Pix
Here are 2 diff Climate Controllers, back side of AC Condensor, Strg Whl Center Disks (orangish tint on rt one = light reflection only), & Frt Seat Blt Receivers...
Wheels/Suspension Pix
And finally (for now), here's last Pix installment, including:
Boxed Stock LCA's,
4 (of 6) Wheel Centers,
Alum. "Champ 500-style" Wheels, &
Painted-black Stock 86/7 Wheels
No serious road-rash on any wheel !
Maxed-out Post at 5 attachments--so will do one more for more wheels/pix
A Couple More Wheel Pix
Per Title...
I'll take 2 of the center caps if not already spoken for. Just PM me a price shipped to 32812 and I can send paypal.
This too:
Pls see pix added of Misc. Brackets; AND, are you saying you 1) want to "see pix" of not-cleaned EGR..., or 2) want to "purchase" same?? Pls advise
I saw the brkts . I need different ones. and pics pls of EGR and clamp
All "spoken for" now, but further interest/payment not yet confirmed...Will definitely put you on the list & will advise you of status soon...If such turns out to be the case, I'd USPS ship 2 to you for $17 total...Thx for interest,,, Monte
Looks same as pix posted--except not cleaned/painted--LOL...Seriously though, it will be tomorrow p.m. before I can retrieve & snap/upload pix---Pls bear with me & I will comply...Thx for interest,,, Monte
Interested in Seat belt receivers/female ends. Are they for a GN? Grey Black? hard to tell from the pic, If yes I will take them
Thanks, Paul
Found Cover...pix incl w/ pix below showing "uncleaned/unpainted" EGR Valve + Bracket,, As requested by 87gta-turbo...Put $5 back in the formula for "either EGR Valve + Bracket"--or to be sold separately...
Ok,,,here ya go w/ requested pix...Wadayathink??...As mentioned in above post, found Cover, so it's available for $5 and is back on the sale-table ... Monte
