Morel short travel lifters
dank GN
BlackArts Automotive (661)993-8277
i am in process of installing short travel lifters . Since they are limited travel what kind of preload do I give them ? Also what kind of valve lash should I incorporate in the setup ? I need to order push rods so would like to know this info to check for the proper length .Another thing what are the touque specs for the rocker shaft to the rocker holder ?
Thank you that's what I needed for the rockers . But how much preload do I set for the short travel lifters . I set my regular morels to .030
Hello my friend I had a set of those lifters this is what I was told tighten down with a 9000 feeler gauge underneath the roller tip once you fill the plunger starting to tighten up stop there lock the rocker pull the feeler gauge out your done this information is from the company that you got your lifters from if you call the phone number on that box they will tell you the same thing .sorry about not finding those push rods for you . Oh and that's if the lifters are dry and have not already been pumped up
Of course on the heel of the cam this is done
