Motor Build questions (clearances etc..)
boostedbuford
Under a rock
Got a quick Question
Basically the motor is a TSM build-
- I got my stock rods resized, now w/ arp rods bolts-
my question is, 4 of my caps are fine, but 2 of them are about .002, .003 thousandths off I can feel w/ my finger nail- from fittin flush-
Is this gonna be a problem?
elaborate on what you mean more "not fitting flush" where & how, a pic. is worth a 1000 words
no my rod "bearing" clearances are fine, it the rod CAP acutually fitting flush on the rod.
I only have a picture of my bigblock so ill use it as example-
where the red arrow points is where I can feel the edge with my finger.
The problem sounds like cap shift, the stock buick rods don't have a real
positive way of centering the cap to the rod . I would try loosing up the
bolts just enough to be able to slide the fork and cap opposite each other
until they are flush. If they won't line up then take them back out and
inspect in greater detail.
