I have a 1970 El Camino that had a 350/350 in it. I found some frame mounts from an early model Buick A Body and bolted them in the designated holes in my frame and moved the tranny crossmember back. The trans is mounted, the driveshaft in and the motor in, but not bolted to the mounts. I neglected to test the fit of the motor mounts on the engine(originally in a T Type) to the frame mounts from an early Buick A Body. The frame mount sits in the motor mount with about an inch of room inside, this cannot be correct. Can someone enlighten me to what I need to do or is it as simple as getting motor mounts from a 6 cyl/small block v8 Buick A Body?
TIA,
Ron
TIA,
Ron
