well awhile ago someone posted a link to the poor mans 11" brake kit,
well i was in need of rear brakes and ordered a set..
all i can say is these things are HUGE!!!!
havent had a chance to try em out for boost holding ability yet hopefully soon..
the only downsides i noticed for my car anyways, the drums are too wide and hit the shock mounting posts slightly.
i had to enlargen the bolt holes for my studs to fit, im using half inch ones.
they come completely assembled had to tear em apart to insatll the parking brake.
this kit is alot heavier then stock too!!!!
also had to open up the hole on the backing plate to fit over the ford type bearing im using.
this kit may work if your all stock
im running the ford type bearing with the flanges welded and such with 31 spline axles. which has been alot of grief finding any type of brake to work,
