mph
85 TR
I let my friend drive my car yesterday and he said he was not imprest at all and thinks he can beat me . He drives a 95 eclipse gst and runs 14.3's at 99, so when i told him my best mph was 97.78 he gave me a hard time. Will my ta 33 give me that mph with a good tune ?
I know i have stock injectors but this is the last race of the year and he wants to race For a 100$ . I know i'll beat him but i want to beat his mph. Do you guys think the ta33 will make up for the trap speed?
thanks
I don't know what kind of tune your car is in but with your mods and the 33 I would think 110mph on good gas should not be a problem. I hit 110mph with a mild combo with my 49 and low boost.
aaaaaahhh i dont know how to tune my car. with out my cam or porting i ran the same mph with the 33@ 97
looks like a darn good combo to run at least 100-105. i think the higher octane, maybe a 20 psi tune, and if you got a good chip, especially good tires (nitto's)-- 105 isn't all too far off, maybe even a 13.20!!!
John
That 33 should support 110mph traps easily, probably quite a bit more. I went 105mph on the stock turbo but I had the wastegate locked shut and it would only make 19psi and fall off at high rpm. I broke the shaft twice also lol.
Throw some good gas in it, start at 20psi boost, start with 02s ~780s, turn the boost up until you see knock or it stops getting any faster. Locking the convertor will add a few mph up top also if you're still using the stock convertor.
thanks for the replys i just need that turbo rebuilt and some injectors and ill let you know how the car does ?
