Been trying to tune my car with the new turbo and noticed that I had an exhaust leak on the driver side header and the number 5 cylinder. I pulled off the manifold and checked my copper gasket (installed 4 months ago) to see if it was warped or cracked. Looked fine and put it back together and it still leaks. Any suggestions on fixing this. Also I was driving my car home tonight and was pulled over for no tail lights. I checked my fuses and my bulbs when I got home and everything seems to be in order. Should I try replacing the head light switch? After I thought things couldnt get worse I noticed that my oil return line from my turbo is leaking and is leaking pretty bad. I checked my gasket and tightened it up it still leaks. Can someone please tell me what I should do to fix my problems. Thanks for your time.
