jasjamz
THS Racer
- Sep 30, 2004
SignUp Now!(wideband) Yeah, I may give the LC-1 a try again. New, and installed like you did that other car. How is his working out? Any issues with his?
I will try one thing before I take it back to him. The flair was a WTF moment! No 2nd hit due to a 2nd exhaust leak now. Had a small repaired spot open back up early in the week. Pushed out a remflex gasket on this test run.:redface: Well that enough to keep me busy for the week ahead.
You can see turbulence in the maf at the top of the run, and the rpm oscillates, seems like a misfire from maybe too rich, or valve float, but more likely tuning. Get the lc-1 and the wide band chip. Best thing you can do.
No problems with the recently installed lc1. Sensor and controller location are key.
You run header gaskets?
Let me know if there is anything I can help with.
