Motor is fresh, trans is fresh with D5 converter. Everything seems good. Car drives nice, has good manners. But it is not as strong as it should be.I have it tuned in on 18psi on 93. Stuck a wideband on it today, and afr is 11.7 in high gear at WOT. It will not get out of the 9s in the 1/8 at 79. Should be running low 8s at 83+. It went 8.65 at 83 with the slipping KCF trans and a D7 converter. No codes, no KR. I'm at a loss on what to check. Its on hard street tires, but traction is not a problem leaving on about 6psi off of the ebrake. I'm stumped.
