Before I begin, I know most of you guys are going to start off with "just get SC&C Stage 2 and be done with it." I'd like to, but I am trying to put my car back together on a TIGHT budget and a few hundred bucks saved on suspension can go elsewhere. I'm just trying to build an all around decent car to drive. Here's what I already have: My motor should be making about 450whp, I have boxed rears with H&R bushings, S10 wheel cylinders and aluminum drums in the rear, S10 RSB, and S10 brakes in the front. I will probably be getting the SC&C spring set because it's only about $30 more than a set of Moogs and I know I'll be getting a good quality set of springs. I will also put on my GTA wheels and get an IROC FSB. Bilstiens will come later.
So....
I really want to go with taller ball joints and found an alternative to Howe that is cheaper. AllStar Performance has adjustable lowers and uppers that will adjust to .5 taller and then some. If I go with their balljoints and put new bushings on the stock control arms I will be saving about $380 over the SC&C stage 2 setup.
Now my question is, will I be able to shim those stock upper control arms to get a good alignment. If I remember right I should be shooting for -.75 degrees of camber and 3+ degrees of caster?? If I can pull this off I'm sure this suspension setup will be just fine for a car that will be mostly street driven. Please let me know if I will have some major issues with this setup and exactly why?
Thanks,
Mike
So....
Thanks,
Mike
