Details of the run:
60' 1.44
330' 4.19
1/8 6.52
MPH 106.68
1000' 8.49
1/4 10.16
MPH 135.06
Screen Name or Car Number Here Jicaju
Race wieght 3755
BLOCK: 4.1 stage II off-center
HEADS: Champion ported TTA
CAM: 218-218 competition cams
TRANSMISSION: PTS 2004R w/bat brake
TORQUE CONVERTER: vigilante 3500 stall lock-up
DIFFERENTIAL: 9-inch ford 3:50 gear
INTERCOOLER: CAS V2
THROTTLE BODY: 70mm precision
RJC POWER PLATE: yup
INJECTORS: 96lbs
THERMOSTAT: 160
TURBOCHARGER: 76mm dual BB precision
VALVE SPRINGS: yup
MAF: nope
DOWN PIPE: 3 inch THDP
EXHAUST: Hooker
FUEL PUMP: single 340
FUEL PRESSURE REGULATOR:
FUEL PRESSURE: 45lbs
ALCHOHOL INJECTION: yup Razors
PROPAIN INJECTION: nah
NITROUS: nah
AIR FILTER AND AIR INTAKE: 4 inch
TIRE DESIGN, SIZE & AIR PRESSURE: Hoosier 28 inch
AIR BAG(s): x2
SUSPENSION: adjustable torque arm/ competition drag shocks
SCAN TOOL: Fast XFI
FUEL: 116
CHIP:
CHIP TIMING: 22 derees
KNOCK RETARD: 0
OXYGEN SENSOR VOLTAGE:
EXHAUST GAS TEMPERATURE:
TRACK ELEVATION: N/A
TEMPERATURE: 55 degrees
PEAK BOOST: 27psi
BOOST AT LAUNCH: 9psi
MILES ON THE CAR/ENGINE: 22,000
60' 1.44
330' 4.19
1/8 6.52
MPH 106.68
1000' 8.49
1/4 10.16
MPH 135.06
Race wieght 3755
INTERCOOLER: CAS V2
INJECTORS: 96lbs
THERMOSTAT: 160
VALVE SPRINGS: yup
MAF: nope
EXHAUST: Hooker
NITROUS: nah
AIR BAG(s): x2
SCAN TOOL: Fast XFI
FUEL: 116
CHIP:
KNOCK RETARD: 0
PEAK BOOST: 27psi
