robzombie
- Oct 10, 2012
Just wanted to show what can be done to increase the oil capacity and keep it looking almost stock by cleaning up the welds.
I should have taken pics of it when cut apart to show where it was cut but the inside pic should give a good enough view.
I had a 4.1 pan that I decided to play with and wanted to make it look stock by tig welding it instead of the typcal mig process that most use. The reason for this is better weld penetration and less grinding and sanding of the welds to keep it strong and less chance for oil weeping out due to inadequate weld tie ins due to start and stops with a chance of a lack of penetration.
In the future I may due a custom flat bottom pan that will hold more oil and increase ground clearance by an inch.
Here are some pics of the almost finished pan.
