jpwalt1987
- Nov 9, 2003
Well today I tackled a project that I have been thinking about for a long time. After figuring out that the billet coupler wouldnt work I went to three different hardware stores to get the fittings I needed. I got a 1/4 NPT T fitting, a 1/4npt to 3/8 compression fitting, two 90* street elbows and two 1/4NPT- 3/8 barb fittings. I had to increase the depth of the pipe threads for everything to fit properly. I also had to shorten the hose barbs some so the overall height would be ok. To supply power to the extra pump I used an idea I saw on here using a nylon bolt and nut with a machine screw through it. It came out good but was a bit of work getting it to fit in the tank. I had to make several adjustments on both the position of the pumps and the angle of the brass fittings. I have about $200 in adding the second pump along with the fittings. Tomorrow I will do the wiring.
