jpwalt1987
- Nov 9, 2003
They are already in my cart !!! Ordering soon as I get home. You guys have awesome products!!
SignUp Now!Now where did you get the idea to use a nylon nut/bolt deal? There are suppliers now that offer more wiring with the stock style set up. When I used the nylon nut/ bolt set up I couldn't find anything that would work. Cool set up by the way
Are you running these two pumps to supply gasoline to your motor?109 block w/ eagle 3.4 stroke crank, K1 rods, diamond pistons, 218/218 .540 lift billet roller cam, ported GN1 al. heads, Borgwarner 6668 turbo, PTE front mount, TT SD chip, 80s, Alkycontrol single nozzle kit, home built 3 1/2 dp, th400 trans. I am stuck at 26 psi of boost right now. The fuel correction starts adding a bit at anything higher. I will post a picture in a few minutes.
Hey guys, I'm in the process of a homemade DP. How are you guys wiring yours?
