I have been working on my GN for over 3 years. Thought I would post some pics.
SignUp Now!6cylboost said:what a machine. looks like u been busy. turned out great
Those are painted with Nite Shade spray paint then clear coated. It is whole process of sanding with 1500 and 2000 wet/dry sand paper between coats etc. I followed the instructions in the "How to" section of the general tech section of this forum. I also have amber LED lights to make sure it is bright enough.Awesome! Where did you get the 'black outs' for the amber lights next to the headlights?
Engine Pics
View attachment 174856View attachment 174857View attachment 174858View attachment 174859 View attachment 174855I have 3 LED lights below the 3 gauge pod. My custom work. Green comes on with fuel pump (it's always on), blue when 2nd fuel pump comes on and red when Evac pump kicks on. Its a blast when all 3 are lit at the same time. Dual fans are Derale rated at 4000 CFM. Oil catch can is custom made by my friend TurboDave231.
I have a GM (LT1 smog pump) installed underneath the front driver's side fender. I removed the round plastic ball that was there. It uses a harness with hobbs switch from Racetronix. It turns on at 4 psi of boost. I will take picture and post here when I get home.Nicely done! Curious as to where you have you have the catch can connected to downstream?
No, not yet. That may be a Winter project.Tony, you ever get the Cruise control figured out?
