KevinB,
Wow! You really started something here ! Good Thread. Guess I'll chime in , encourage, and predict you WILL make it . But everything will have to be " right -on". There are responses from some very knowledgable people here. Dusty, Stangbanger, GN87Mike, and Quick6n KC are giving some good info........ No need for me to get into what 's already been said. I've witnessed Stangbanger run 10.7's at the GS Nat's this year. His GN is the "real deal". ( Even if he has got a "runner-up "addiction
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). His GN is a high-strung , fine tuned machine that runs consistantly in the 10's with a TA-61 turbo and a stock longblock. Proceed carefully, and you'll be there too. And as stated you WILL need good weather, a low 1.5 60ft., high boost,(30# min),loose some weight( 3550# would be good), C-16 fuel and absolutely NO knock !!!!.........and remember, you are living on the edge here, so be mentally preparred just in case. You will be pushing your factory components to an extreme, but your goal is a do-able one. Good luck !!
If it helps anyone, you can see my buildup in the May/June issue of the Buick GSX-tra magazine. It's very similar to most street combo's. Titled "10 sec TA-49/ factory longblock".
The " TINMAN"
87 GN, stock unopened factory longblock, v-2 frt mountI/C, Red's 107 chip, 55# inj's, 9/11 conv, LImit TA-49 turbo,and ................of course a "TINMAN "Cold-Air intake system! .......10.93 @ 123.8mph w/ 1.51 60ft.
www.modelman5.com/tinmancoldairkit.htm
