87gn-newbee
- May 25, 2001
Try now, was set as Private.
Badass man... I hope to get a ride in that beast some day. Looks and sounds awesome man.
SignUp Now!Try now, was set as Private.
You use the Holley Dominator computer, not sure which route is practical with stock harness.
what size rim and tire are on the rear looks real good perfect.While the car is at the shop getting some last minute welding done, here she is ready to go!
IMG_20170414_193926608
IMG_20170415_204450942
Wow, impressed with the hard work and making it happen. I'm dropping mine off, I'm burnt out on messing with these things so huge respect for doing it so clean.
I'm going this route myself but LS2/L92 aluminum combo with CX Racing headers/DP kit, but what turbos you running and what boost or power you looking for?
In the "FWIW" dept: I took the fuse panel out, removed all the unused wiring, and left the body, lighting and basic power to dash, etc, in place. I used those sources for the Dominator, and other 12V switched devices.
Can’t really say anything bad about that! At twice the boost it’s going to be a monster.
