My Wideband is not listed on the powerlogger drop down menu, What now?
this is the one i picked up http://www.daytona-sensors.com/WEGO3.html
i hooked it up to the PowerLogger using "AEM Gauge 0/5" from the drop down menu as it looked closest to the readings.
can it stay like this or is there another setting i should use?
thanks for your help
David
The AEM Gauge setting will work. Also the PLX setting will work. Those have the same output in the 10-18 afr range.
Eric
