TurboTnZ06
Go on red!
- May 7, 2002
Only 10 more "It won't fly" votes needed! C'mon!
SignUp Now!Ummm.. I don't know. Maybe catapults are more EFFICIENT than a treadmill would ever be, and by turning into the wind, MAXIMUM AIRFLOW can be achieved....![]()
The question is slightly unclear: if the conveyor "tracks the plane's speed" and keeps it exactly zero, then obviously, no, the plane would not take off as it would be stationary with respect to the air. I don't see what could possibly be difficult to understand about that.
The way the question is worded though, it could mean to say that the plane moves forward at 150kts, while the conveyor belt moves backwards at 150kts, for a rotational speed of 300kts for the wheels. In that case, as long as the wheels don't burn off, the plane would take off.
Perhaps the wording is all that is causing the problem there...
Looking only at friction, and assuming the aircraft could take off if unhindered the cases are as follows:
Case 1: If the treadmill is frictionless and the wheel bearings have any amount of friction, the treadmill will move (in the direction of flight), the wheels will not turn, and the plane will lift off.
Case 2: If the treadmill has any friction and the wheel bearings do not, the treadmill will not turn, the wheels will turn, and the plane will lift off as if on a conventional runway.
Case 3: If the treadmill and wheel bearings have infinite friction, the aircraft will sit there under maximum power and not move, unless maximum power overcomes the friction between the wheel and the treadmill, then all hell breaks loose.
Case 4: If the treadmill and wheel bearings both have some friction, but not enough to stop the plane from reaching takeoff velocity, either the treadmill or wheels will turn, or both the treadmill and wheels will turn, and the plane will take off (albeit with a longer takeoff roll than in Cases 1 & 2)
Case 4 is what actually happens and has a few subcases to it:
Case 4a: There is a threshold of treadmill friction where, if the wheel bearings have a much smaller friction, the wheels will turn and the treadmill will not.
Case 4b: Conversely, it's possible for the wheel bearings to have a relatively high friction compared to the treadmill where the treadmill turns and the wheels do not.
Case 4c: It is also possible for combinations of treadmill/wheel bearing friction to have both the treadmill turning AND the wheels turning during the takeoff roll.
I don't know how else to tell ya' man. The plane will take off just like it normally would. Re-read the posts here about why it will move and take off just like it would on a normal runway. Maybe it will click. If it does click, come back and save a little face.![]()
I absolutley understand what you are saying:
that since the wheels arent driven by gear, and are free rolling they would just be spinning at double the speed they normally do at take off speed since the 'jet' is pushing it.
BUT my interpretation of the question is that the conveyor halts any forward motion by counteracting with the exact opposite power. and therefore since no forward progress is achieved no take off is achieved.
Now do you see my point?
What exacly is the conveyors job? that is the reason for the divide here.
Let's keep going with this. Do you think if they did place a plane on a treadmill and ran it in the same direction as the plane that it would take off a hell of alot quicker and in a much shorter distance?
It would, and it should. Hence the reason for the catapult on the aircraft carrier.
Am I missing something here? - I'm assuming the the plane will remain stationary while moving, like a runner on a treadmill. That is, I'm assuming that like a runner, the plane does NOT move forward on the treadmill.
Now if the plane moves forward fast enough on the treadmill to go forward, AND pass enough air over its wings, then it MAY fly. But what would be the point of that experiment?
If it remains stationary it WILL NOT FLY, in my opinion.
If it does, I'll buy a parachute as an additional safety device the next time I run on a dyno. I'll also install a rear wing for the additional downforce on the rollers.![]()
If the plane doesn't remain stationary, then what is the point of the experiment?
There is the key. The question relates the speed of the treadmill to the speed of the AIRPLANE, not the speed of the tires. The treadmill cannot match the speed of the tires. If the tires are going 10mph as soon as the treadmill is going 10mph then the tires are instantly going 20mph, as soon as the tires are going 20, the treadmill goes 20, now the tires are going 40. You can match the treadmill to the planes speed. If the plane is going down the runway at 20 you can speed the treadmill to 20 but the wheels will be going 40 You cannot have the wheels and treadmill match speeds.
An altimeter not only tells you the distance from the ground. It can also tell you how fast the aircraft is approaching the ground. Probably the most important cockpit instrument there is in my opinion.
I understand what most are arguing in the pro argument. Thrust will over come the speed of the treadmill, creating forward motion. The treadmill in turn would speed up negating the effect of thrust.
Thrust alone will pull SOME air across the wings, it would take an enormous amount of thrust, spread out over an enormous airsurface for this to occur.
Your knowledge of aviation is lacking.
An altimeter does not tell you how fast an aircraft is approaching the ground. An altimeter only tells you how far you are from sea level. It makes this assumption based upon barometric pressure. Every time you take off you have to calibrate an altimeter to atmospheric conditions in order for it to give you a relatively accurate measure of altitude.
Altitude is not a measure of distance from the ground it is a measure of your distance from sea level. (I told you this before, apparently you did not read it) For every 1000 feet you go up you lose 1"HG of pressure. An altimeter is nothing more than a fancy barometer.
Repeat after me, Altimeters Do NOT tell you where the ground is!
There is an instrument that measures how fast you are changing in altitude, and that is the vertical speed indicator. An altimeter does not tell you how quickly you are changing altitude unless you have a supercomputer for a brain. Most people don't and thats why most aircraft have a VSI. It too operates based upon pressure changes. I could tell you how it works but I'd be wasting my breath.
Neither of these instruments have anything to do with where the ground is in an airplane. For that you need maps and navigation equipment to know what the terrain is like around you.
The treadmill is irrelevant. Nothing the treadmill could do can counteract anything the airplane is doing. Airplanes move air to fly, not ground.
You are correct also that airplanes use air for travel. Where will that air come from if forward motion is negated?
One can't use a model plane on an exercise treadmill and call it an accurate scientific experimentation, since the speed control is way off, and it doesnt have the capability to keep up.
They are ignoring this concept.
Most contend that the conveyor is limited to counteracting the speed of the planes wheels; sort of like a shortened runway idea.
BUT if the conveyor counteracts the speed of the plane AKA the velocity of which it travels forward,then the plane is limited to a stationary area.
Like I said this experiment would be hard to duplicate in real life. You would need a super high speed, low friction conveyor and willing to risk destruction of a plane (and conveyor) when the wheels/bearings hit critical limits.
