- Sep 24, 2010
So SALVAGEV6 was pretty much right on the money.....
Some 'o you guys are pretty damn good with these cars.
SignUp Now!Its a catch 22. If the MAP loses connection then your bubble goes to 100 KPA since the engine isnt runningdid the dropping MAP show in the logfile?
B
Razor said:Its a catch 22. If the MAP loses connection then your bubble goes to 100 KPA since the engine isnt running![]()
But when I saw that car few months ago.. I could have sworn the bubble was at 100 kpa.. not buried down in the vacuum zone. Thats why the ignition module was deemed the culprit..maybe maybe maybe.. hard to remember what I did last yearIf the map losses the electrical connection it will go to -14.5psi (on xfi log). Because its reflecting zero volts
I wish there was a prize or something, But Hey You About Won, It was in that connector, but it was how the Alky got tied in with it.If it uses the factory ECM connectors and wiring harness you can always check behind the glove box for this connector which is off the ECM/IGN fuse and is needed for stock ECM power and also powers the module electronics MAF and ESC I think.
It is a pink/blk stripe wire in cavity F, one side is a fatter wire than the other side and both sides of the connector are the same color.
It's right behind the glove box and wrapped in foam you can't miss it, worth a wiggle and dumping whatever is in the glove box on the passenger floor.
You can see clearly where I had to bypass my connector and I put the electrical tape over the heat shrink tube and soldered splice.
Cool. But now I need some new issue to follow on this site.
D
Glad you all found it quickly.
