NEWCHAPTER
Need Speed
- Jun 8, 2003
Trying to install caspers cam sensor cap .... I was turning the engine over by hand and using a hose felt the compression in #1 cylinder (drivers side closet to front of car) so I check to the timing mark and it is not lined up so I keep turning by hand to line up to the 0 mark and it seems pretty far... so i tried it a second time and as I was starting to turn it , it felt like where I had it was sucking in air thru the hose .... is this right???
