Need a pic of the hardlines in front of tank
John Larkin
Sublime Master of Turbology
I had mine down to change out the rubber hoses. I know there is a bracket that holds the vent line and feed line but what holds the return line? Mine was just floating in air. The rubber separator is down by the tank holding the lines apart just as they go between the tank and the trunk floor. Is this separator supposed to be more midway up the lines? I don't know and need a pic to get it put together right if someone would not mind crawling under and snapping a photo for me. TIA.
