Originally posted by tracy
I am undecided about what to do for an intercooler -
Simple....FMIC
Originally posted by ACLR8R
Has anyone tested the before and after temps of the PTE or the Thunder Fab?
Originally posted by Back-N-Black
Tracy send you a pm.
To be a little more precise, what matters is the plenum DENSITY. The density is a function of both temp, and pressure. That said, it won't matter much where you measure the temp, when you are comparing ICs, as long as it is the same point for all of them. Measuring at the plenum, or just ahead of the throttle body, will give the front mount a very slight advantage in that there is a tiny amount of cooling that takes place in the pipe from the IC to the throttle body. There is also a pressure drop, also small, in that same run of pipe.What matters is the plenum temps
The "ultimate setup" varies, depending on what you want to do with the car. Street use, street/strip, salt flats, etc, all have different requirements, and benefit from different compromises. The stock location has the advantage of not blocking the radiator, or the A/C condenser, and it is cheaper than the front mount, and should give better throttle response. The front mount will certainly cool the intake charge better. So figure out what you want it to do, and how much you want to spend, then decide.
Originally posted by bruce
For the ultimate set up you want alky and a F/M.
Originally posted by d0n_3d
just make sure you do the cooling mods before you even think about doing a front mount on a close to 100% street car...I have an aluminum radiator and the dual fan setup on my car...temps never go above 165 and usually hit 160 when the thermostat opens
