So Im putting the Valve body back on the trans and I end up snapping a bolt. The bolt is a M6x1x45mm bolt. According to the CK Performance book , this bolt should be torqued down to 140 inch lbs. Now if Im not mistaken, 12 inch pounds is equal to 1 ft lb correct?
So I go over to Napa and look at there bolts. My bolt says TR 10.9 on the head. Napa's bolt says W.T 8.8 on the head. So I ask the lady " Hey dont you have some stornger bolts like grade 8 stuff?" She tells me this is better than grade 8. Im like my bolt says 10.9 on it, wouldnt a 8.8 bolt be weaker. Shes says no, so me as a dumbass (Im ASE Master Cert., she's aprobly a High School Grad..... like 30 years ago) think, hey maybe this lady knows more than me. I get home and dont even think about putting them in until I look up some info. Turns out 8.8 grade bolts (metric) are weaker than 10.9 grade bolts which are weaker than 12.9 bolts. So now Im looking to order some from this website I find and look further and then another question pops up.
Is the CK Performance manual wrong? According to the link below, 10.9 bolts are good to 10 ft lbs. Using my calculation of 10 ft lbs = 120 inch lbs (1 ft lb= 12 inch lbs) would I just keep braking the bolts if I keep torquing down to 140 in lbs? The first one I torqued down would not stop at 120 inch lbs, it would keep twisting and twisting and I knw it was gonna break. So I did the second one and it kept twisting and twising till about 130in lb when it broke.
US & Metric Bolt Torque by Grade
So my question is :
1) Am I correct by saying 10.9 metric bolts are stronger than 8.8 bolts?
2) What is the torque spec for the valve body bolts?
thanks again fellas!
So my question is :
