Not for a stock combination but I have some basic data on 3 100 Octane Chips for Blue Tops from the traditional vendors, injector constant is omitted.
Chip-1:
Bottom Timing: 23 Degrees
Top End Timing: 26 Degrees
Wastegate Duty Cycle: 100 down low / 89 up high
Projected Boost: 17-18 PSI
Fueling Notes: Lot's of fuel, injectors go static in upper RPM's
Chip-2:
Bottom Timing: 28 Degrees
Top End Timing: 24 Degrees
Wastegate Duty Cycle: 90 flat
Projected Boost: 18-19 PSI
Fueling Notes: Less fuel than Chip-1, more than Chip-3
Chip-3:
Bottom Timing: 30 Degrees
Wastegate Duty Cycle: 100 Flat
Fueling Notes: Leanest chip of the 3
Maybe this will help get you started.
