JDSfastGN
- Jun 16, 2001
Well if you have followed along i fixed first gear, it was a stuck low 1 valve. The tranny shifted great for 400 miles and all the shifts are still very good, but I'm concerned because the 2-3 shift seems to have softened a bit. Its not slipping by any means but its not chirping the tires at part throttle like it had and you can't really feel it, and with much boost it just isn't there like it should be. It also concerns me because the TV cable is pretty far back compared to where it used to be to get the close to the same shift quality. i wouldn't think with the bigger PR and TV boost valve, PTS pump, dual feed to the clutches, and such would need so much TV. I am also running a 3 speed 200 servo if that helps, could a seal have started to leak on it to cause this 2-3 softness, i wouldn't call it a flare because there is no delay and it is very fast but its not hard like it has been and I think should be
Here are my numbers
min TV 1500
P 80
R 95-100
N 80
OD 80-83
D 80-83
2 190
1 175
max TV at 1500 rpm
P 210
R 180
N 200
OD 190
D 180
2 195
1 175
Why does my L/R Boost valve appear to be working at min TV but not at Full TV? I'm thinking they are not working as they should. Thanks a lot guys. Sorry for all the length if there is any other info i could provide just let me know.
Here are my numbers
min TV 1500
P 80
R 95-100
N 80
OD 80-83
D 80-83
2 190
1 175
max TV at 1500 rpm
P 210
R 180
N 200
OD 190
D 180
2 195
1 175
