The boost off the line spools slow from 5-10#Originally posted by salvageV6
You should check to see off the line if the boost drops way below the 5 psi. and then has to climb back up again or if it just spools slow to 20 psi. or whatever you run up top.
From 5 psi. to 24psi. my 51 is like lightning.
Not always quite as fast from vacuum to the 5 psi. however.![]()
