parts list 87 g.n.
well where do i start .i am at work and all paper work is at home so ill go off memory .block stage 1 252 ci carillo crank carillo rods girdled .je pistons ,block was bought from chattanooga tennessee ,a guy called geeker??? i guess he is big time down there ! postons 110 cam 42 1/2 green strip 009s,turbo ta 60 redone by turbonetics ,terry houston 3"d.p .poston headers and cross over ,heads fully ported and polished champion cast ,intake old bgc max flow ported to match heads done by valley performance and machine ionia mi. ,19 row stock location intercooler ,smc methanol injection ,billet f.p regulator ,2 walbro 255 f.pumps hot wire kit ,tps enhancer ,turbotweak chip,373 gear ,trans by art carr ,3200 stall ,hemco 70 mm plenum race version ,70 mm accufab t.b.adjust waste gate .do have scanmaster.i cant think of anything else right now ,if need specifics on rod lenth and crank size will have to find papers cuz my mem sucks also dont remember specs on cam .what do you think it should run ???? 11.40s best w/bfg drag radials at us 131 drag strip.i think i need bigger injectors ??? run 26 psi no knock 02 815 f.p set 45 off line :biggrin:
