We're on a streak of 100* days in Texas and I'm just getting around to addressing the A/C that hasn't worked since last year. The GN is a daily driver again so I'd prefer to have the A/C working. I had it evacuated and charged in 2009 and it lasted about a year.
With engine running, AC on and blower on high the compressor clutch does not engage. Direct Scan shows A/C is set to on from the ECM. With the compressor not engaged the high and low side pressure is reading 110. I hot wire the compressor per the manual and the clutch engages and low side pressure goes down to 45 and the high side goes to 245. Those numbers appear to be about right in the manual. It seems to be cooling some when I hot wire it but I'm reluctant to leave it hot wired long enough to see how much it will cool. Need an expert's opinion on this. We're melting down here. Thanks.
