I just reread dynoman's post. I guess I misinterpreted it. I saw the "some use..." and then he spoke of the two different brands of sealant. Now I see in the last part of the last sentence...the pesky little word need. Sigh...
So what you're telling me, is I have to do it all over again.
If you put your threads in dry, yes you have to pull the studs out. Those holes do go to water and that water will be pressurized shortly after firing up the engine.
Honesty a GM seal tab will fix the leaks but you don't want water between the stud shafts and the head FOREVER if you don't have to have it there.
.....oh yeah don't but antifreeze in the radiator on the initial fire, just use water from the garden hose or the back of the toilet tank.
If its on the stand and the headers aren't installed yet, I'd back the nuts off one at a time. Just enough until they are lose then use the hex wrench to remove the whole assy. Pull the studs one at a time and jizz them up with sealant. Then run them back down.
This is going to be a time consuming tedious thing with no reward of a mechanics high, so go ahead and get plenty of beers and fire up pornhub for some background noise.
When you're done at least your nuts-to-studs threads will have one more cycle on them to half fully marry the threads.
When you wake up tomorrow, back them off 1/4 turn one at a time and retorque them starting from the inside out. If you dig being all ANALytical, mark the starting point then note where the fasteners land when you're done with the second pass. You might dig the results. Granted it's not as fun as mentoring know-it-all millinials, but real science is actually pretty rewarding. ESP when you can see it in real life
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
