SignUp Now!Nope. Carry on..
Relax alittle...
What process did you use?
I know this is a bit late to ask this question, but were the heads new from champion ?
You have to use the sealant! Some go into the water jacket and will leak water!
Champion Irons. Not sure how Nick came to get them, but he told me they were fresh/new. I believe he's better known to be more of a TA Performance kind a guy, he had them basically at the ready. They look 100% as he said...fresh and crisp, as if they came straight from Champion...so I have little concern that they're not nice an' flat.
On the torque, hand tight means 'hand tight', not 'hex wrench in your hand' tight'
You should be safe then,I just always check them with a straight edge because of my last fiasco.
It doesn't cost anything and only takes a couple of minutes,and can save alot of time, money and future headaches .
Unfortunatly i didn't think to suggest it earlier.
Good luck ,i feel your pain on this build, with all the time, money,and aggrevation you have had with it ,hopefully you'll catch a break on this go-round.
Also i would do a search about heads leaking coolant,i'm pretty sure there has been a few threads about using sealant on the studs because of them going into water jackets.
I was wondering about that, and even learned that the older generation studs (from ARP, I presume) from didn't come with hex holes in the end of them. But I watched two vids, both of whom sounded like they knew their stuff (I'm sure you've seem some vids of guys who appear to be wingin' it...and decide to make a vid while they're at it). Two vids I saw, one guy specifically mentioned that while it's supposed to be "hand tight", he actually torques his to 10 lbs. I didn't give that one too much weight, while ARP studs, it was on a Honda head.
The one that I went by was this one (though unfortunately, I ignored the sealant):You'll notice he uses a T-handle hex wrench and appears to tighten them with even a bit of force. I didn't do that. I used a screwdriver handle ended tool, but stopped as soon as I felt resistance. Probably 2 lb torque. The guy in the vid above looks like he was pushin' 10, and the other guy mentioned he goes 10.
To me, that just seems too odd, to try and tighten a stud with one's fingers only...what if the threads aren't in the best shape and one can't screw it in sufficiently with their fingers, gripping threads on the top end of the stud?
The bottom line is...what problem could it cause? The stud is down in there fairly good. I definitely didn't over tighten it.
See...there's so much to learn. Never thought about checking the heads for flatness. Like you said, I'm probably fine, being that they're from Champion. I think they condition and machine their heads awesomely, from what I remember. But still...a quick straight-edge check would've been so easy.
And that's so funny...I Goog'ed and Youtubed on heads install...never thought to look for a sticky. But in hindsight...that was just a bonehead move on my part - major. I got the tip this afternoon, and watched another vid as well. Dynoman's words "some use..." stuck in my brainium and I just mistakenly concluded it was optional. I had Locktite on my mind, and that's just another lesson to me. I had never heard about sealant before, and just wasn't paying attention. So now, "alllllrighty then" takes on new meaning - gotta do it over again tomorrow.
The good news...is I'll do it right. I'm okay with that. It was a beautiful day today. I'm in no rush. There's still lots o' work to do. I'm not thinking about it yet, but I'm realizing that I think some of the PITA things will be bolting all the accessories, crank sensor, and other miscellaneous components back on - when I didn't take them off! I r&r'ed a TR motor in '02, and so I can't exactly tell you that my memory is fresh on how all that stuff goes together.
But...I'll worry about that later. Tomorrow: Redo the studs with sealant and then put the rear main cap back on with a new seal.
