NEED HELP ASAP
before you do that (the log may have saved the params wrong)
your MAP sensor is reading ZERO........
This is more likely the issue.
Bob
last week we were looking at a voltage shift in your MAP sensor when the lights and fan were on. What did you change since then?
Bob
Bob
Just did the change over for the sd2 chip that's all and put in all new fuses for car. The voltage dropped to 12 1/2 from 13 1/2. I put the car on the slow charger for the battery.
in that case, make sure the analog cables are plugged all the way in on the PL and analog unit.
do you have a voltmeter handy?
Bob
measure voltages at the MAP sensor (all three terminals) and at the analog unit where the MAP sensor connects.
Bob
do you have access to the factory shop manual?
The MAP sensor is fed 5 volts and ground from the stock boost gauge. These pass thru that black/clear connector behind the glovebox.
Without a MAP signal, it will not run.
Bob
Bob
No I don't have access to the factory shop manual and someone email me it? Does the signal of the maps sensor just go out when it has been working all before?
