Need Help finding 4an male fitting.
87 WE2
I cannot seem to find anywhere a male -4an hose end. I need a -4an male end on a -4an line.
If anyone knows were to get one, please help.
I have found them in -6an (see pic) but nothing in -4an. Pic of what I need below:
gntxc2 would probably (definatly) know. I would PM him or maybe he'll poke his head in here.
No room for all of that stuff I just want clean hose ends, Its for an inline oil filter to the turbo in a stock size braided line stock location hidden out of sight.
I found a 4an-4an male union thats not too bad it might be the way I end up going. This filter I got has a male 4an end and female 4an end which is making it tricky, but it filters down to 10 mic so Im willing to make it work. I am replacing my current filter which was in the same line, it only filters to 60 mic. has worked great just want more filtering capability.
:cool:
Is the female end of the filter, -4AN threads? Is the end open or does it seal against the AN flare? A pic would help.
Billy T.
gnxtc2@aol.com
:cool:
Billy T.
gnxtc2@aol.com
Both ends of the filter are an threads its an open female end with a an tapered seat. It will seat right against a male AN hose end. I just need to find one, I can get a pic if nessesary but I know I need a 4an hose end with a male 4an threaded end with the an taper on the end to seal.
Thanks for the help Paul, yea its for a turbo oil feed line filter. I am going to check out the place in Philly. If that does not work out I'll get the adapter.
Bad design. I would opt for the end to be open and use an o-ring seal. After a few filter changes, the AN seal will deteriote. I'm not a fan of a twisting motion to seal against the AN taper.
Billy T.
gnxtc2@aol.com
Billy T.
gnxtc2@aol.com
It should be OK as long as he breaks the hose end connection if he needs to and leaves the adapter in the housing.
