I'm trying to diagnose a knock problem. Stock turbo, 30 lb injectors, SMC methanol kit and a new TT chip. WOT O2 readings are 775 and EGT's are around 1200. At 18 psi, I am seeing up to 4 degrees of knock. I am running 91 octane and I just installed the RJC power plate but it did not seem to help. I shouldn't be seeing any knock at 18 psi with methanol injection. Where should I start...could it be false knock?
